Hi all!
I upgraded from a Mini to a Taz 6 at Christmas and I’m trying to dial things in. I’m finding that my layer changes are leaving a significant seam, and on most prints there are blobs as the layer starts.
I use the latest Cura build, and I’m working with Matter hacks 3.0mm PLA and I’ve changed a bunch of settings in my attempts to fix things. I’ve lowered the print temp, I’ve enabled retraction at layer change, I’ve enabled coasting, I’ve moderated speeds so they’re consistent, I’ve started the layers on the inside wall.
I’m happy to give more info, I’ve also attached a photo of one piece with no blobs, but a very pronounced seam. There’s another photo of 2 unfinished rings that have the seam, then seemingly random blobs that start half an inch from the seam, and finally I have a txt export of my files that I cleaned up for readibility, in case it helps.
I’d appreciate any advice you guys can give.
