I’m using a Windows 7 operating system. I’ve just downloaded the driver successfully. Once I got the Pronterface program up and running, it showed a COM7 available, but will just say “Connecting…” forever. I close the program and open the pronterface.exe text file and it says:
serial.serialutil.SerialException: could not open port COM7: [Error 5] Access is denied.
If you don’t mind, try checking with a new user account in Windows, to see if anything else you may have installed locally is interferring with comport access.
Once the driver has been installed under the new account, reboot both the computer and the printer. Sign into the new account and connect the TAZ 3D printer. Run Pronterface and attempt to connect.
Have you been able to connect to the 3D printer through USB previously? If this is the first time that you’ve tried, contact us at Support@LulzBot.com with your order number, 3D printer serial number (found on the rear of the printer, at the base of the electronics enclosure). Screen shots of your device manager screen showing the RAMBo line entry and the properties tab will help identify were the connection is failing.
