any updates?
when I bought my Taz at the beginning of June I fully expected to be able to print PC as advertised and was a bit miffed to learn the polyschnozzle was not compatible with Taz when I went to purchase the kit.
any updates?
You can always “make it fit”…don’t let the man tell you it can’t be done…just DIY
http://www.lulzbot.com/?q=Polyschnozzle-Kit
it says it is only compatible with the polyschnozzle 1.1, so I suspect that is why it says it is not compatible with the TAZ, since it comes with a 2.0
So just buy a 1.1 and the kit, and swap out the hot end. You might need to do a few more things too, like get a longer screw or make an extension or something for the Z limit switch, since it looks like the tip is MUCH longer, and would hit the bed without this mod.
wow, that looks like a glass busting mod : )
thanks for the idea, I’ll take that possibility into consideration while I practice a bit more patience.
It could be glass-busting…if you do not also mod the Z limit switch, like adding an extension to the screw that activates it.
I suspect that is why it is labeled as not for TAZ.
