Is there a way to know what the order of print will be? I want to fab multiple objects of varying height and want to lay them out in Cura so the print head clears the objects - IE. optimally back to front on build plate.
Thx,
John
Thx,
John
If you opt to print your models one at a time vs all at once you can see what order the models will print by slicing your models (press the prepare button, unless it does that automatically, I did turn that feature off). Change from Solid View to Layer View. Then run the simulator (play button) or slide the slider down & up to view the print layer by layer.
