Hey Guys,
I was hoping someone could help me out here. The 3D printer I use is the Stock Lulzbot Taz Workhorse with the .5mm nozzle. I’ve been trying to figure out how I can use it to print Minifigs for D&D, Warhammer and the like. Admittedly I’m a beginner and not sure what settings to put in. I tried to follow video tutorials for printing minifigs but the settings I copied were for an Ender 3 and not a Workhorse. The filament I’m using is the Polylite PLA Black.
Listed below is the URL of the specific models I’m trying to print and I’ll List the Cura 3.6.20 Settings I tried to use. I also ran the printer at 50% speed and it didn’t seem to help any. If anyone knows better settings I can use please copy paste them. I’d be really appreciative.
Goblin Models (Goblin_wit_mace_and_shield, Goblin_wit_bow_and_arrow): https://www.thingiverse.com/thing:2840687
Cura 3.6.20 Settings: PK ! B3s\ç ç # lulzbot_redgum_goldenrod_miniatures[general]
version = 2
name = Miniatures
definition = lulzbot_redgum_goldenrod
[metadata]
type = quality_changes
setting_version = 4
material = PolyLite_PLA_(Polymaker)_lulzbot_redgum_goldenrod
quality_type = standard
[values]
acceleration_enabled = True
acceleration_print = 250
bottom_thickness = 0.8
cool_fan_full_at_height = 0.2
cool_fan_full_layer = 2
cool_min_layer_time = 7
cool_min_speed = 2
default_material_print_temperature = 230
expand_skins_expand_distance = 1.5
fill_outline_gaps = True
infill_before_walls = True
infill_pattern = grid
infill_sparse_density = 35
jerk_enabled = True
jerk_print = 5
jerk_travel = 5
layer_height = 0.1
layer_height_0 = 0.2
material_flow = 92
material_print_temperature_layer_0 = 215
retract_at_layer_change = False
retraction_amount = 6
retraction_combing = noskin
retraction_count_max = 90
retraction_extrusion_window = 2
retraction_min_travel = 0.8
retraction_prime_speed = 10
retraction_retract_speed = 10
retraction_speed = 10
skin_line_width = 0.3
skin_no_small_gaps_heuristic = False
skin_outline_count = 2
skin_preshrink = 0.8
skirt_brim_speed = 21
speed_infill = 42
speed_layer_0 = 21
speed_print = 42
speed_slowdown_layers = 2
speed_travel = 100
speed_travel_layer_0 = 50
speed_wall = 21
speed_wall_0 = 21
speed_wall_x = 42
support_enable = True
support_type = buildplate
switch_extruder_retraction_amount = 10
top_bottom_thickness = 0.8
top_thickness = 0.8
wall_0_wipe_dist = 0.2
wall_line_count = 3
wall_thickness = 1.2
PK ! ’u\íÕ Õ ( base/lulzbot_redgum_goldenrod_miniatures[general]
version = 2
name = Standard
[metadata]
type = quality
setting_version = 4
[values]
acceleration_roofing = 500
backlash_fading_distance = 1.0
bottom_thickness = 1.25
brim_line_count = 10
carve_multiple_volumes = True
cool_fan_full_layer = 5
cool_fan_speed_min = 100
cool_min_layer_time = 15
cool_min_layer_time_fan_speed_max = 0
cool_min_speed = 5
default_material_print_temperature = 215
expand_skins_expand_distance = 0
fill_outline_gaps = False
infill_before_walls = False
infill_pattern = lines
infill_sparse_density = 30
layer_0_z_overlap = 0.5
layer_height = 0.25
layer_height_0 = 0.35
layer_start_x = 141
layer_start_y = 141
line_width = 0.5
material_bed_temperature = 45
material_bed_temperature_layer_0 = 55
material_final_print_temperature = 210
material_initial_print_temperature = 210
material_part_removal_temperature = 35
material_print_temperature_layer_0 = 210
material_probe_temperature = 160
material_soften_temperature = 180
material_wipe_temperature = 170
prime_tower_size = 7.745966692414834
raft_airgap = 0.5
retract_at_layer_change = True
retraction_amount = 1.5
retraction_combing = off
retraction_count_max = 99
retraction_extrusion_window = 3
retraction_hop_enabled = False
retraction_min_travel = 3
retraction_speed = 15
skin_preshrink = 0
skirt_brim_minimal_length = 250
skirt_gap = 5
skirt_line_count = 2
speed_infill = 40
speed_layer_0 = 15
speed_print = 40
speed_slowdown_layers = 3
speed_support = 40
speed_support_interface = 40
speed_topbottom = 35
speed_travel = 170
speed_travel_layer_0 = 70
speed_wall = 35
speed_wall_0 = 35
speed_wall_x = 35
support_angle = 60
support_bottom_stair_step_height = 0.5
support_bottom_stair_step_width = 5
support_brim_enable = True
support_brim_width = 5
support_enable = False
support_infill_rate = 15
support_interface_density = 50
support_interface_enable = True
support_interface_pattern = lines
support_interface_skip_height = 0.25
support_join_distance = 3
support_offset = 0
support_use_towers = False
support_xy_distance = 0.5
support_xy_distance_overhang = 0.5
support_z_distance = 0.5
switch_extruder_prime_speed = 10
switch_extruder_retraction_amount = 20
switch_extruder_retraction_speeds = 10
top_bottom_thickness = 1.25
top_thickness = 1.25
travel_compensate_overlapping_walls_enabled = False
wall_thickness = 1
zig_zaggify_infill = True
PK ! B3s\ç ç # lulzbot_redgum_goldenrod_miniaturesPK ! ’u\íÕ Õ ( ( base/lulzbot_redgum_goldenrod_miniaturesPK § C
