I have switched to the .25mm SL print head on my TAZ 6.
The last problem that i have not figured out is how to adjust the bed operating temperature.It is running 20 degrees Celsius lower than when I was running the stock .5mm head.
I am printing with ColorFabb nGen. It needs a temperature of around 90 degrees C. and I am getting 65-70 degrees C. I lose adherence after about 10 layers.
I’m sure the problem is an easy fix, I just can’t seems to find that fix…
