What do I have to do to get a profile for a 0.4 nozzel using 3d Fuel filament?
Use the 0.5mm nozzle profiles, but reduce all the line widths by 20%.
Change the nozzle size in the machine settings:
Just type “width” in the profile settings search bar and adjust. .4mm is fine for a .4mm, you can go slightly thicker (up to .5mm) if you desire.
I am using ‘Cura LulzBot Edition - 4.13.10’ and SideKick 747 MET175. I do not find a ‘nozzle size’ setting in the printer settings.
