I’ve been using the Sidekick 747 for a few months and the prints are great. However, last week I noticed that on the initial layer the hotend is lightly dragging, which is causing print failure. With the z axis raised there is a vertical wobble. This is not side to tside but up and down. The gantry wheels are a little loose. I have looked for instructions on how to adjust them but I can’t find any.
Ideas on what the problem really is or how to adjust the wheels would be very helpful
Thanks.
I’d check that everything looks right according to those instructions, but it sounds like you may have a wheel with a flat spot from being too tight and/or not being moved enough. Flat spots can be worked out by just moving the wheel enough back and forth to let it even back out, or you can buy a new wheel and install according to the linked instructions.
Been lurking for a couple years as our school has one of these and I am the one that updates software/firmware when needed and tweaks hardware. Picked up a used Sidekick a couple of weeks ago for myself and in the process of rebuilding it. I know this is an old thread but for those who may have the same question I will tell you what I found. The toolhead mount is not super precision in that it and the bolts/rollers it uses are not a tight precision fit. If your printer has a lot of prints on it you should probably change the V rollers out and/or loosen all bolts for V roller then squeeze top/bottom pair of rollers towards each other while tightening their respective bolts. This will ensure a tight fit as possible and should eliminate most wobble. I built a toolhead using a E3D Hemera | 0.4mm nozzle and just got it all going last night. It is in there now printing a 4 hour christmas tree ornament job and looking good
