Hi @Wrathernaut,
The tool head is the SK175 with an E3D V6 brass 0.5 mm nozzle. AFAIK, this is the default print head that comes with the SideKick 747. The “Initial Layer Height” is set to 0.425 mm in Cura (this is the default with this printer/toolhead). I also verified that the toolhead is set to “SK175 | 0.5 mm | BRASS” on the printer.
From what I can tell, there are 3 main issues going on (which may stem from the same underlying problem or separate problems).
1 - Bed adhesion. The first layer is simply not sticking no matter the temperature, Z offset, or how much I clean the bed. I can remedy this by using a gluestick, but I don’t think I should have to do that to a fairly new PEI sheet.
2 - Z offset, as you mentioned. I did a basic 1-layer print and manually adjusted the Z offset by 0.03 mm increments throughout the print to create a gradient of “nozzle too low” to “nozzle too high.” As you can see in the photo, Around -1.3 mm offset gave the best-looking “squish.” I did use glue for this print to get everything to stick.
3 - Some sort of y-axis slop or play. Belt tension seems fine, and the bed does not move if I try to push/pull it with my hand while the servo is active. However, the top and bottom of the square fill seems to drift in and out whereas the sides look even/straight.
After cleaning the bed with warm water and dishsoap, letting it dry, and rubbing it again with isopropyl alcohol, I tried some additional Z offset tests this morning. I printed 4 50x50 mm squares to see if adhesion was any better. It was only marginally better. But, I did notice that as I raised the nozzle, the y-shift problem got worse. You can see how the nozzle does not seem to want to fully go to the outline of the squares on the tops and bottoms, but is fine on the sides.
Any idea what would cause this y-axis drift? That might be another avenue worth pursuing.
I can simply over-extrude or slow down the print on the first layer, but that does not seem like it would fix any of the underlying problem(s).
