I have created a 25.4mm x 25.4mm x 25.4mm cube in Rhino and exported as an .stl file. I loaded the cube into slic3r and generated a gcode file. When viewing the file in Repetier it looks as if each layer moves slightly in the x and y direction which creates an offset between the top and bottom of the cube.
Is this a slicer issue or a Rhino export issue?
Looking at the gcode in online viewers the offset does not appear, only in Repetier.
I have included the slic3r output.
Cube.gcode (196 KB)
