BTW, those bed washers are precision machined specifically for these printers (this is not a source-able part … they are machined specifically for these printers). But the washers are resting on some stainless steel bushings that are NOT precision machined. These bushings are a source-able part (e.g. a good fastener store could source them for you.) and they don’t have a very tight tolerance.
I used my micrometers to check both the washers and the bushings … again, washers are pretty much perfect (error down to thousandth’s of a millimeter). The bushings had quite a bit of error (too much).
I pulled mine being very careful to note which corner each bushing came from. I discovered that two bushings were noticeably shorter (by something like .23 to maybe .26mm … (a layer height – more or less).
Also… I had a tall/short/tall/short so that one set of opposing corners was tall and the other was short (this would have a curved surface like a pringles potato chip.) The amount of error and the shape of the error makes it hard to compensate.
I wanted to fix this.
There are two choices… the cheap way, and the expensive way.
Cheap way: measure the height of your bushings … make sure the two shortest are on one side of the bed and the two tallest are on the other side of the bed so that any un-level-ness is linear.
Expensive way: get more precise bushings. (Naturally my OCD decided this was the way for me!)
I ordered a new set of stainless steel bushings from McMaster-Carr (online). I own two LulzBot printers (so qty 8 10mm x m3 bushings) and ordered another 10 from McMaster-Carr. I measured them all … found the four that have the closest measurements to each other, and installed them. (BTW … this might have been luck but all 10 of the bushings I ordered from McMaster-Carr were much closer to true tolerance than the bushings that came with the printer. They were off by maybe .02mm when checked with quality micrometers (so… around 1/10th of a layer height rather than a full layer height).
Note: For the OCD who might be reading this (and you KNOW who you are), THIS is the part: McMaster-Carr (Again, I don’t know if it was just dumb luck… but these were much closer to spec than what happened to be in my printers).
This helped considerably.
I don’t suggest everyone run out and buy an expensive pair of micrometers. I do … kinda suggest that if you care about precision then maybe a decent pair of calipers would be good to own. (Mitutoyo have really good stuff with excellent repeatability. Note these are sold in various lengths. They aren’t the cheapest but their digital calipers have excellent accuracy and repeatability.)
I also used my calipers to test if my bed rails were truly parallel – and discovered they were not (loosening the bolts that hold them in place … I was able to adjust them.
Once you own a decent set of calipers, it’s surprising the number of uses you find for them.
Micrometers, on the other hand … I wouldn’t necessarily recommend everyone run out and buy them. (MANY years ago I worked in a machine shop programming CNC milling machines … so I happen to own them.).
