Hi.
I need springs for my TAZ 5 but it seems that I can’t buy from Canada. The website that I found is that:
https://www.lulzbot.com/store/parts/spring-6-pack-6mm-od-97mm-fl
Is there a site that I can have those from Canada?
Thx
Hi.
Thx
You might check with https://itworks3d.com and see if they have a set they would ship you. If not you should just be able to use any locally available 6mm diameter 9.7mm long spring you can find. Automotive shops may have them for carburators, Hardware stores usually have assorted spring packs that may work. Ace hardware often has them in the U.S. I don’t know if that chain continues into Canada though.
