Hi all, my trusty Taz 5 has developed a seemingly strange and serious issue with the X Axis.
When I go to home or move the X axis, it makes an aweful graunching sound, and the movement is exteremely juttery, and it eventually halts the machine.
When I turn off the printer the X Axis by hands slides back and forth smoothly.
Also the belt appears in nice condition and is adjusted properley.
Thanks very much. Hummm, well that’s a bit strange, I did the test, it seemed both axis then functioned properly, which is weird. I then put it back and the printer appears to be functioning perfectly (so far)
So it’s either an intermittent fault, or perhaps the connections weren’t sound.
If it is intermittent, please check the stepper motor cables. It could be that you have a loose connection somewhere or a wire that is starting to fray or break.
Thanks, well after 2 successful 5 hour prints it started doing it again this morning. So I swapped the X and Y on the board and the X was still the issue.
I assume that infers the problem lies between the board and the stepper motor, so cable, connectors or stepper motor itself?
Well, it looks like I found the problem. Spent some time cutting and re-soldering, and it appears to be working. Might have a search and see if I can buy a new X-Axis look to keep as a backup in case my repair eventually fails. Thanks for your help!!
