The cables that run to my y axis motor drag on my heated bed clips for the first few layers of the print. Has anyone come up with a simple but clean solution to this? I am concerned that it will cause a wire to fail eventually.
Zip ties and printable wire retention clips. You can also clock the motor body down by rotating it to move where the cable path goes if necessary.
Thanks for the advice. I accidentally said y axis when I meant x.
Oh. the Y axis cable shouldn’t be anywhere near the bed. You have it routed wrong or something then.
