I received a TAZ 5 last year as a donation to my classroom. It had been working fine until about a month ago when I fried the board. Does anyone know of an idiot proof method to get it back to working properly? Everything seems to be working except for the extruders. Any help would be appreciated. Videos would probably help more than written instructions.
How much heat? The firmware won’t let the extruder move until its something like 170c at a minimum. 200c is a good target before attempting movement.
Does the extruder stepper motor turn with a consistent resistance if you turn it by hand with disconnected from the board? if it’s been fried, it will usually feel harder to turn somewhere in the rotation. If a dead motor fried the board, or the other way around, you could have ruined the new board as well.
Use a known good motor (X axis motor can be connected to the extruder motor wires fairly easily) to see if it moves when you try to move the extruder after temp is up. I wouldn’t recommend doing the extruder to the X axis initially, in case the motor is killing stepper drivers. Motors are much cheaper to replace in case the extruder stepper driver kills the motor.
Thanks! I was able to figure that out after I sent my last reply and after I was able to get the hot ends to finally heat up correctly (I had some wires crossed). I do appreciate your help! With it being an older machine, I wasn’t sure I would get any responses, let alone one on the same day.
