I own a Workhorse & Pro … both have 300x300mm build plates. This means my start g-code would be using different x,y coordinates to find the wiper pads vs. a TAZ 6 (which has a 280x280mm build plate).
When you install Cura, it installs all the start/end g-codes for every printer & toolhead they’ve ever sold. (On a Mac this is hiding in /Applications/cura-lulzbot/Contents/Resources/cura/resources/gcodes … but I don’t know where they hide it on Windows.)
Anyway, here’s the generic start g-code for a TAZ 6 (the X,Y coordinates in this file should be good and hit the wiper pad on your printer). Start g-code will vary based on the actual toolhead. If you have a different toolhead, don’t use this code. Also, LulzBot uses internal codenames for products and you’ll find these in your filesystem (if you snoop around the Cura install). This makes it a bit harder to determine which file is the file you need.
LulzBot Mini printers use codenames based on names of flowers.
LulzBot TAZ printers use codenames based on names of trees (except I find the TAZ 5 & 6 are usually actually just called TAZ 5 or TAZ 6… the Workhorse is codenamed ‘redgum’ and the Pro is codenamed ‘quiver’.)
LulzBot extruders use codenames based on names of caterpillars.
The SE 0.5 toolhead (which I think is the standard toolhead on a TAZ 6) is the ‘cecropia’.
;This G-Code has been generated specifically for the LulzBot TAZ 6 with standard extruder
M73 P0 ; clear GLCD progress bar
M75 ; start GLCD timer
G26 ; clear potential 'probe fail' condition
M107 ; disable fans
M420 S0 ; disable previous leveling matrix
G90 ; absolute positioning
M140 S{material_bed_temperature_layer_0} ; start bed heating up
M109 R{material_soften_temperature} ; soften filament before homing Z
G28 ; Home all axis
G1 E-30 F100 ; retract filament
M109 R{material_wipe_temperature} ; wait for extruder to reach wiping temp
G1 X-15 Y100 F3000 ; move above wiper pad
G1 Z1 ; push nozzle into wiper
G1 X-17 Y95 F1000 ; slow wipe
G1 X-17 Y90 F1000 ; slow wipe
G1 X-17 Y85 F1000 ; slow wipe
G1 X-15 Y90 F1000 ; slow wipe
G1 X-17 Y80 F1000 ; slow wipe
G1 X-15 Y95 F1000 ; slow wipe
G1 X-17 Y75 F2000 ; fast wipe
G1 X-15 Y65 F2000 ; fast wipe
G1 X-17 Y70 F2000 ; fast wipe
G1 X-15 Y60 F2000 ; fast wipe
G1 X-17 Y55 F2000 ; fast wipe
G1 X-15 Y50 F2000 ; fast wipe
G1 X-17 Y40 F2000 ; fast wipe
G1 X-15 Y45 F2000 ; fast wipe
G1 X-17 Y35 F2000 ; fast wipe
G1 X-15 Y40 F2000 ; fast wipe
G1 X-15 Y30 Z2 F2000 ; fast wipe
G1 X-15 Y25 F2000 ; fast wipe
G1 X-17 Y30 F2000 ; fast wipe
G1 X-15 Y25 Z1.5 F1000 ; slow wipe
G1 X-17 Y23 F1000 ; slow wipe
G1 Z10 ; raise extruder
M109 R{material_probe_temperature} ; wait for extruder to reach probe temp
G1 X-9 Y-9 ; move above first probe point
M204 S100 ; set probing acceleration
G29 ; start auto-leveling sequence
M420 S1 ; activate bed level matrix
M425 Z ; use measured Z backlash for compensation
M425 Z F0 ; turn off measured Z backlash compensation. (if activated in the quality settings, this command will automatically be ignored)
M204 S500 ; restore standard acceleration
G1 X0 Y0 Z15 F5000 ; move up off last probe point
G4 S1 ; pause
M400 ; wait for moves to finish
M117 Heating... ; progress indicator message on LCD
M109 R{material_print_temperature_layer_0} ; wait for extruder to reach printing temp
M190 R{material_bed_temperature_layer_0} ; wait for bed to reach printing temp
G1 Z2 E0 F75 ; prime tiny bit of filament into the nozzle
M117 TAZ 6 Printing... ; progress indicator message on LCD
Here is the other (note the start comment that this g-code is for the SE 0.5mm Tool Head):
;This G-Code has been generated specifically for the LulzBot TAZ 6 with SE 0.5mm Tool Head
M107 ; disable fans
M420 S0 ; disable leveling matrix
G28 XY ; home X and Y
G1 X-19 Y258 F1000 ; move to safe homing position
G28 Z ; home Z
G1 E-15 F100 ; retract filament
M420 S1 ; enable leveling matrix
G4 S1 ; pause
The difference in these two start g-codes… the ‘standard’ one does a ‘G28’ (home command) on line line 11. This is a “home ALL axes”. But the SE 0.5 toolhead version does a ‘G28 XY’ which only homes the X & Y axes, but not Z. It then moves the toolhead, pre-heats it to soften temp, and THEN homes the Z. (not sure why it waits).
IMPORTANT NOTE: If you want to test this on it’s own (e.g. just save it to a memory card and run it through the printer) make sure you search for everything inside curly braces { } and replace those with actual numbers.
E.g. if using PLA, the ‘soften’ temp is probably 180, the wipe temp is probably 170, and the probe temp is 160. So you’d replace the line that says:
with
M109 R180 ; soften filament before homing Z
Curly braces are Cura variables. When Cura sees them in the start g-code it will use the material & quality profiles to find the values and substitute the actual numbers for those variables. The Marlin firmware in the printer doesn’t actually know how to interpret {material_soften_temperature} (or any other variable) and wants to see actual numbers.
I’m mostly concerned with your comment that the nozzle isn’t properly touching the wiper-pad on the side of the build plate. In other words… it’s not getting scrubbed clean.
I actually don’t trust that the nozzle simply “appears” to be clean… I’ve found that the nozzle can build-up a micro-thin layer of material such that it looks clean, but has a coating which semi-insulates it from conductivity. Think of this like the layer of “seasoning” that builds up on cast-iron frying pans. While that’s great for cookware… it’s bad for bed leveling on a 3D printer. We want to get rid of that layer.
I use a small brass wire brush (about the size of a toothbrush) and I scrub the nozzle clean (with the nozzle heated to 170°C so that the material is soft and easily removed).
CAUTION: I have found it is possible for the brass bristles to touch the heater wires and this can trigger a spark … and that can’t be good. So now I’m very careful how I wipe the nozzle with the brass brush to stay away from those wires. But I will say that ever since I started giving the nozzle a gentle scrub with the brass wire brush … bed leveling got a WHOLE lot better. (it’s rare that I have anything less than a perfect bed level.) This did not used to be the case when I didn’t brush the nozzle.
