What is the problem?
Taz 6 running MOARstruder crashes when asked for nozzle reclean.
Killed. Printer Halter. Please Restart
Thank you in advance.
What did you already try to solve it?
I have checked the start up GCode to the best of my abilities and have tried replicating the issue while printing from a computer. Only happens when printing through OctoPrint/Pi.
Simultaneously posting with Lulzbot community to see if there have been other similar issues and have compared gcode to the ones I found.
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, … as much data as possible )
OctoPrint: 1.3.12
OctoPi: 0.17.0 on RPi 4
Printer: Lulzbot Taz 6 (Marlin 1.1.9.34)
Browser: Chrome
OS: Windows 10
Slicer: Cura LE 3.6.20
2020-01-10 03:52:43,709 - octoprint.filemanager.analysis - INFO - Starting analysis of local:LTAZ6M_IdHolder.gcode
2020-01-10 03:52:43,712 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/LTAZ6M_IdHolder.gcode
2020-01-10 03:52:43,735 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: LTAZ6M_IdHolder.gcode, owner: _api, user: _api
2020-01-10 03:52:43,744 - octoprint.util.comm - INFO - Changing monitoring state from “Operational” to “Starting”
2020-01-10 03:52:43,748 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: LTAZ6M_IdHolder.gcode, owner: _api, user: _api
2020-01-10 03:52:43,752 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-01-10 03:52:43,764 - octoprint.util.comm - INFO - Changing monitoring state from “Starting” to “Printing”
2020-01-10 03:55:38,569 - octoprint.util.comm - WARNING - Received an error from the printer’s firmware: Probing failed
| Last lines in terminal:
| Recv: echo:busy: processing
| Recv: T:141.17 /140.00 B:60.05 /60.00 @:0 B@:32
| Recv: T:141.18 /140.00 B:60.00 /60.00 @:0 B@:38
| Recv: T:141.02 /140.00 B:60.03 /60.00 @:1 B@:32
| Recv: T:140.69 /140.00 B:60.01 /60.00 @:9 B@:35
| Recv: T:140.21 /140.00 B:60.06 /60.00 @:24 B@:27
| Recv: T:139.84 /140.00 B:60.04 /60.00 @:35 B@:30
| Recv: T:139.54 /140.00 B:60.08 /60.00 @:45 B@:23
| Recv: T:139.30 /140.00 B:60.04 /60.00 @:55 B@:28
| Recv: T:139.26 /140.00 B:60.02 /60.00 @:57 B@:30
| Recv: Error:Probing failed
2020-01-10 03:55:38,572 - octoprint.util.comm - INFO - Changing monitoring state from “Printing” to “Error: Probing failed”
2020-01-10 03:55:38,579 - octoprint.filemanager.analysis - INFO - Starting analysis of local:LTAZ6M_IdHolder.gcode
2020-01-10 03:55:38,579 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2020-01-10 03:55:38,586 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/LTAZ6M_IdHolder.gcode
2020-01-10 03:55:38,634 - octoprint.util.comm - INFO - Changing monitoring state from “Error: Probing failed” to “Offline (Error: Probing failed)”
2020-01-10 03:55:39,020 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.124) 6.00ms
2020-01-10 03:55:39,036 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.124) 5.00ms
2020-01-10 03:55:40,000 - octoprint.filemanager.analysis - INFO - Analysis of entry local:LTAZ6M_IdHolder.gcode finished, needed 1.42s
2020-01-10 03:55:41,028 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.124) 9.16ms
2020-01-10 03:55:41,058 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.124) 10.57ms
