Hi,
After installing and one successful 8 hour print with PLA+/Pollydisolve S1, the heating on extruder zero failed mid print during the second print.
I cleaned up, tried again, failed again, about same time (after about 10 minutes)
Not sure if this is related to the dreaded heat creep in dual extruder v3.1 (am printing the suggested adapter for the fan meanwhile).
I do have two heater cartridges (24v 30w Heater Cartridge, 225mm | LulzBot | Hexagon Hot End ) so I can replace the broken one if this is indeed the issue. (funny thing, SAME issue happened with my single stock extruder on taz 6 and replaced the heater cartridge, that’s why i have these spares now).
Any suggestions? Could it be the thermistor instead? I have a multimeter and I can test them…
Anyhow, any comments would be appreciated, whether you think it’s the heater cartridge and if it’s related to the heat creep.
Alin
