I’m having difficulty finding a way to only use the rear extruder on my flexydually. Can someone please let me know how this can be achieved. I’m using Cura, Lulzbot edition.
When I load in the rocktopus and press print, it stops after the following lines:
I tried setting the extruder nozzle temp at 0C, that did not work.
I tried setting the extruder nozzle temp at 200C, that did not work.
It still stopped or gave me an error.
My printer was not starting prints after leveling because it was waiting for the bed to heat to the set degree. The bed was not heating up all the way.
I called lulzbot and they told me what to check to see what was wrong with the print bed.
I Checked the resistance between the 2 red wires on the left side of the print bed.
I Checked the resistance between the 2 white wires on the left side of the print bed.
They were both reading correctly so the bed was not broken.
I opened the left panel to see the inner circuitry and checked the 15 amp blue ato fuse.
I took that out. It was not blown. I firmly placed it back in.
When I started a print again, the bed heated up to set temperature and the printer was able to follow through the process and work correctly!
