Holly cow. I read your response, and thought to myself; well of course it’s a 5 volt fan. I bought the same one that is indicated in the original post!..
Then I double checked my purchase (and subsequently the package…
Major brain fart on my end. Turns out I unknowingly bought the 12v version!!!
“Morse Code” on the bed… that’s a sign the nozzle is too close to the bed. The filament is being blocked, and when enough pressure builds up its extruding to relieve the built up pressure in the nozzle.
Don’t feel bad. There’s apparently a real issue with which fan you’re actually getting when you buy that one from certain sources. I almost did the same thing. You’ve got to really make sure, and even then, double check what it says on the actual fan itself. Assuming you’re going to try again with the proper fan, let us know how it turns out.
