Taz Pro - Homing fails on Y axis
Taz Pro Runing CuraLE 4.13.1, firmware 2.1.3.0.18
Earlier today I updated the firmware via CuraLE. Now printer is failing to home along the Y axis. Bed moves, hits the stops but the belts continue to run until the sad tone plays and I get the Homing Failed message.
I can manually home the X and Z axis from the LCD. If I manually home the Y axis, bed moves forward to the stops and the motors/belt continue moving.
Any ideas?
Try adjusting the sensorless homing sensitivity.
Went from 4 down to 3 under sensor less homing, and it homed the Y axis successfully.
Thanks for the help,
jj
THANK YOU! Fixed my PRO Y axis problem immediately! :grinning_face:
