Hello all,
I am working on a TAZ Pro with M175v2 machine head.
I recently had a failed print that resulted in the hotend getting covered in PLA. I turned on the printer and heated up the hotend to soften the PLA.
I realize in retrospect that this was dumb to do, especially while the machine was on, but I was using a pointed metal pick to try to pull off the PLA that was in the cracks. I got too close to the heater cartridge on the back side of the hotend, and when I did, there was a spark, and the printer turned off.
Now, when I turn the printer on, it turns on like normal and I can navigate the menu items on the touchscreen. But now whenever I tell the printer to heat up the hotend, the printer quickly shuts off and comes back on again. The same happens when I try to send commands to move the X, Y, or Z axis. Interestingly, I can tell it to heat the bed and it does that fine without restarting. The thermistor seems to be reading the temperature correctly still as well.
I suspect that I fried something on the board…but I need help figuring out what to do next. Are there diagnostics I can run to figure out exactly what is wrong? Is there a way to repair the damage to the board, or am I looking at totally replacing it?
Thanks,
Phil
