Hi,
Got my Taz5 Dual V2 in about 3 weeks ago (dynamism UK) and after installing I noticed some issues.
It hangs forward very much. I had to put extra washers in the front head for it to be on the same Z level as the back.
I must have needed a full 3 mm. That was to be overcome.
It was printing fine, only did some small stuff.
But now, I cannot print anything anymore without it going wrong.
Symptoms:
- The display on the printer itself is not displaying correctly. Like its got the wrong resolution settings.
If I go into the menu and change temp on the front ext (for example) I see the word temp on the left bottom corner but the value half on the right top corner. - Extruder temp on the back extruder cannot reach higher then 212 degrees, even though in menu I select 230
Doing a single filament print
- Front extruder : after about a layer or 3 (1.5 hours) , the front extruder wheel stops turning. The program continues but no filament is coming out (3 reprints same issue)
- Back extruder: After 4 layers (further then the front extruder at least) , it goes bananas , starts full travel speed X axis, slams through Home and starts grinding like nuts
Never had a single issue when running the single head for over 500+ hours in the last months
Got a major deadline coming up so need any advise here!
Regards
Sander
