TAZ6 Completes Print Before it Starts
Hi, my TAZ6 goes through its normal calibration before starting a print. Right after it finishes leveling the bed it parks the head and says print complete. This is happening with the Lulzbot FW AND Klipper FW. I have reinstalled an older version of the Lulzbot Cura Slicer to no avail. Why is it stopping right after the bed leveling??
Turns out its the specific STL file I was trying to slice. It does not like it for some reason. I tried a rando STL from Thingi and it works fine now. I don’t understand why it wouldn’t like the STL if the slicer handles the Gcode creation.
If you post the offending STL here, we can probably give some idea of why it’s failing.
It seems to be too small. If I scale it up to 500% then it shows material used and ETA. It has to do with the nozzle diameter and line width.
