I don’t know if this is the proper place to discuss this, so if not, please point me.
I have my Taz6 running Marlin 1.1.8.62 on a home built Titan Aero 1.75mm extruder with a 12mm diameter inductive probe.
When adjusting the Taz6 Marlin for my needs, I ran into a problem with the SanityCheck.h erroneously telling me my probe could not hit the bed when using corners, X=0, Y=25, X=195, Y=221 (probe is at X=+43,Y=+13). I experimented with the rear Y value and it would compile using somewhere around Y=265. Not acceptable to me. So I ended up modifying the sanity check code to omit the Y check. Everything is working fine, but I would prefer that the software correctly approved Y=221. I would like this info to get the the correct folks to do a check on the anomaly, and not sure how or where to do that.
Very pleased with with the performance so far. A newer mount design is ready. I got tired of fighting the PEI bed removing PETg. I also want to eliminate all the nozzle scrubbing. I may still use use the wipe function to a lesser extent, but there are other ways of dealing with ooze.
I’m including a preliminary photo. I have to machine the magnetic bed yet and am temporarily using spring clips.
A newer extruder mount is currently printing. Will post all later.
