Thingiverse .stl not printing well with Cura
Hi… I downloaded this Thingiverse file.
I Cut the gcode in Cura 3.6.7 and it printed badly. The default settings generally print fine so I’m wondering what others might see (and could please share?) what I could adjust in settings, please? Thank you.
LTAZ6_bobcat.gcode (4.6 MB)
First layer barely has any contact, so it’ll probably detach.
The bucket is only one layer thick, so it’ll barely exist.
Body has no support under it:
One-line thick scoop walls:
Impossible overhang angles:
Single dots of filament stacked:
Floating segments:
So… bad model in general. Print settings won’t do a thing for this.
This is not Lulzbot cura (to my knowledge)
Wrath… Thank you so much for perusing that for me.Did you see all that under Cura 3.7? I’ll download a different model. Thank you again for all your kind help.
You’d see all of that by looking through your print preview in Cura, but I just loaded it in PrusaSlicer’s GCODE viewer for the screenshots.
A bit of a trained eye would easily see it in the model before even trying to slice though. Thin, skinny details just don’t FDM well. Even with resin, you’d have a tough time with that model.
Still developing that trained eye. Thanks.
Also remember that many of the models on there are made to use the 0.4MM nozzle size hot end. So the layers may not print properly.
