If any of you run larger spools, this holder will let you move them to the top of the machine to save some bench space.
I have also added a version of this mount that will work on 1.5 inch extrusion like the stuff used on the gMax.
That looks great! I like how the CG is over the vertical extrusions.
Thanks. It works well. We added a printer and needed the bench space that was being occupied by the stock spool holder so, this was the result.
