I’m having trouble getting my TAZ 6 to behave. It seems to put down a layer or two successfully, but then starts mashing the print head into the existing layer.
As part of my troubleshooting I’ve tried the following:
Placing the printer on a large tile to ensure it is 100% flat
Replaced the controller board with an Archim2 (including using the heatsink, heatsink compound and heatsink retainer from a TAZ Pro) and Drunken Octopus firmware
Increased the current of the Z axis driver up to the point where it will buzz
I’m not sure what I should look at next. Stepper motors, power supply?
The stepper motors and driver both stay very cool, so I don’t think this is the issue.
Has anyone else had this issue? I was really surprised when the controller didn’t fix the issue.
I’m using the Aerostruder v2 with this release of Drunken Octopus firmware.
I was getting the exact same issue with the Rambo board running whatever version shipped with Cura LE 3.6.37, I would have to rig up a bench power supply to double check.
This is on an old machine that was working fine previously.
Z offset could be compensating and making first couple layers okay by printing higher so the overextrusion results in thicker layers, but after that, extra material had nowhere to go but up and into the path of the extruder.
It was the extruder steps set for the wrong print head, the problem was manifesting itself in the same way as before I changed boards, so I jumped to conclusions.
