Does anyone know what causes this? This is Silver ABS. I haven’t had this issue with any other color I’ve printed. I thought it was low temperature, but raising it didn’t seem to have any effect. Raise it more? Anyone have any ideas?
Thanks for your help!
The metal ABS’s are weird with their temperatures. The additives tend to push them outside the normal expected range, and I never know if its going to be up or down. That looks like overheating to me actually… I’d try dropping your temperature lower than normal and see what happens, or even turn on the cooling fan when you get to the same spot on a low level.
Your starting layer also looks a little too close to the bed, which may be causing some overextrusion.
