On my Lulzbot Mini v1, I started to get the “MINTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!” error and figured that I need to replace the Bed Harness cables:
I can’t seem to find this part anywhere. Anybody have any ideas?
I was only looking in the v103 section, so I never saw this! I assume these cable instructions would work for v103 too.
Initially, I tried printing today and got a probing failure. Then I took off the RAMBO cover and noticed the extruder mosfet output plug could be pushed in a tad. After this, it is printing about 44 minutes without issues and still going as I type. The temp of the bed does seem to drop sharply about 20 degrees and come back to 60 degrees. It happened twice after about 5 minutes into the print, and I just saw it again at 45 minutes into the print. I wonder if these dips point to a bad bed or bad thermistor wire? Or is it no problem at all?
Thanks Iggy. Wow! What a great thread you made. I need to print out a new front idler too. It has a visible crack around the bolt…still seems to work though.
Today, I took apart the printer to take a look at the bed harness cables.As I was disconnecting the yellow thermistor connector cable, it fell apart in my fingers. One of the yellow cables going into the black molex connector fell out. It looks like I need to strip the wire and crimp it? However, that would make one of the two wires shorter…do you think it would still work? I would hate to buy a big spool of this wire and like a pack of those molex connectors and just use a little of it… Any ideas?
Adding this link to this thread in case others are also still searching. At this point, I’m looking to upgrade to something with a larger print volume, but want to keep using my Mini in the meantime…
