Here’s one converted from the STL file. It’s not the origional step file, but it should be identical for the dimensions and geometry. Taz 4 X Carriage 2_0.stp (2.52 MB)
Piercet - thanks for the help and posting this, but it still doesn’t work for me. I can modify the file now in my CAD software, but then it doesn’t allow me to output the modified back to a STL file to print. Evidently, I still need the original step or any other original CAD file that I can bring into CREO for modification.
BTW - my modification is very simple…I just want to reverse the 2 clamping screws from pointing upwards on the stock to pointing downwards, since I have the autoleveling hardware attached to the x carriage below the clamps. The setup is working ok, it just would be nice to be able to clamp and unclamp the belt from above instead of from underneath.
