Random new problem that appeared tonight (which causes the nozzle cleaning phase to fail). I can’t move the print back “backwards” - only forwards (to front of machine)
I checked all other movements - nozzle X,Y,Z good, bed forward good.
Any idea what’s wrong? I hear a slight buzzing sound when I press Y backwards.
That sounds like your y endstop is getting triggered for some reason. This could be a fault in the wiring, the endstop, or the RAMBo itself. You can test if the limit switches on the printer are functioning correctly by first move the Mini’s bed to the middle of the Y axis so that neither of the limit switches are held down. Then connect to the printer using Cura, in the Cura console there will be a text box along the bottom of the window to enter in commands. Enter in the command M119 and hit enter it should show that both of your y endstops are open if one of them says triggered that will most likely be the cause of your problem.
Try this again with the bed pushed all the way to the front of the Y axis, and once with the bed pushed all the way to the back of the Y axis. Lastly disconnect the wires on both Y axis limit switches and try the test one more time, make sure to power off the printer when disconnecting these wires. If it is triggered even after it is unplugged it will mean there is something going on with your RAMBo or the wiring. You can narrow this down even more by unplugging the endstop at the RAMBo and sending the M119 command again, if after unplugging the wires from the RAMBo they are still triggered it will indicate an issue with the RAMBo.
Your RAMBo is the computer board that controls your printer. It is located inside the control box on the side of your printer. To direct you towards the correct RAMBo and the instructions for installing it I will need to know what type of printer you are dealing with.
Unfortunately there are two different versions of the Mini and their wiring is a little bit different, on the back of your printer is a serial number that would allow me to figure out which version you have if you want to post that I can point you in the right direction for a RAMBo and instructions.
I know it’s a few years since you’ve had this problem. But maybe I can help someone out there.
I recently picked up a Mini V1 with the same issue.
I was able to resolve it by moving the center spade connector for the Y min trigger to the top spade connector on the actual endstop trigger under the bed and then by switching the center pin/wire to the open spot on the connector on the Rambo board.
You’ll need to remove the panel to get to the board for the Rambo board connector pin/wire move .
You’ll need a pick or a needle to remove the pin from the connector that clips to the Rambo board labeled Y min. Flip the connector over til you see the small silver square for that center pin. Press your pick or needle into silver square area and then pull the pin/wire out of the clip connector. Then move the center wire/pin to the open spot and plug it back up. Get it all back together, power it up and then run your M119 command to see if it’s all open.
Once I did this my printer is working again. I am guessing somethings wrong with the board for that pin and moving those two connections fired it right back up.
