I have been building all of the parts used on the TAZ 6 to get some experience with the TAZ 6 printer, and to have spare parts on hand.
I found the hard way that x_carriage_guide_v2.stl has the part upside down but x_carriage_guide_v2-x4.stl has 4 parts right side up.
But the biggest problem I have run into is that the y_idler_mount_v4.0.FCStd is not the same part as the one that is on my TAZ 6.
The one that I printed has the cylindrical cutout in the base extending under the smaller of the shaft supports. This is a structure that can not be properly built without support material since there is a part of this bearing support that hangs down.
The one that is on my machine does not have the cylindrical cut out extending under the shaft support. On this one, the base is solid, and the shaft support is not hanging in air.
I verified that the one I built is the same as what it looks like in FreeCAD, so the design file is wrong.
Could someone please direct me to the correct design file?
Thanks.
Edit: added a picture of bad part. I should not be able to run a string through it the way I have.
Thanks for bringing this to our attention. Was this the file pulled from download.lulzbot.com (which is incorrect, we’ll get it updated ASAP) and have you checked the included file on your SD card?
None of the parts design files were on the SD card for my machine. Were they supposed to be on the SD card?
I downloaded all of the design files from your web site.
The contents of my SD card were as follows:
$ ls -R
Contents of SD Card
./Contents of SD Card:
benchmarks calibration functional LulzBot modifications novelties README.html
./Contents of SD Card/benchmarks:
3Dbenchy make_2015_tests make_torture_test marvin_keychain
./Contents of SD Card/benchmarks/3Dbenchy:
3Dbenchy_nGen.gcode 3Dbenchy.stl attribution.txt LICENSE.txt
./Contents of SD Card/benchmarks/make_2015_tests:
all_tests_at_once.gcode bridging_test.stl fine_positive_features.stl overhang_test.gcode XY_resonance_test.gcode
all_tests_at_once.stl dimensional_accuracy_test.gcode LICENSE.txt overhang_test.stl XY_resonance_test.stl
attribution.txt dimensional_accuracy_test.stl negative_space_tolerance_test.gcode XY_resonance_1.0mm_walls.gcode Z_resonance_test.gcode
bridging_test.gcode fine_positive_features.gcode negative_space_tolerance_test.stl XY_resonance_1.0mm_walls.stl Z_resonance_test.stl
./Contents of SD Card/benchmarks/make_torture_test:
attribution.txt LICENSE.txt torture_test_nGen.gcode torture_test.stl
./Contents of SD Card/benchmarks/marvin_keychain:
attribution.txt LICENSE.txt marvin_keychain_nGen.gcode marvin_keychain.STL
./Contents of SD Card/calibration:
0.50-Noz_calibration-100mm-90_taz6.gcode calibration_octopus_taz6_nGen-high-speed.gcode XYZ_tester.gcode Z_tester.gcode
burnin.gcode extruder_calibration_taz6_nGen.gcode z_shipping_245.gcode
./Contents of SD Card/functional:
mobile_device_rack
./Contents of SD Card/functional/mobile_device_rack:
attribution.txt LICENSE.txt stand_3_nGen.gcode stand_3.stl
./Contents of SD Card/LulzBot:
LulzBot_keychain rock2pus rocktopus
./Contents of SD Card/LulzBot/LulzBot_keychain:
attribution.txt LICENSE.txt LulzBot_keychain_nGen.gcode LulzBot_keychain.stl
./Contents of SD Card/LulzBot/rock2pus:
attribution.txt LICENSE.txt rock2pus_nGen.gcode rock2pus.stl
./Contents of SD Card/LulzBot/rocktopus:
attribution.txt LICENSE.txt rocktopus_nGen.gcode rocktopus.stl
./Contents of SD Card/modifications:
spool_mount
./Contents of SD Card/modifications/spool_mount:
attribution.txt LICENSE.txt spool_mount.gcode spool_mount.STL
./Contents of SD Card/novelties:
fish_fossilz mustache_ring OSHW_logo
./Contents of SD Card/novelties/fish_fossilz:
attribution.txt fish_fossilz_nGen.gcode fish_fossilz.stl LICENSE.txt
./Contents of SD Card/novelties/mustache_ring:
attribution.txt LICENSE.txt mustache_ring_nGen.gcode mustache_ring.scad mustache_ring.stl
./Contents of SD Card/novelties/OSHW_logo:
attribution.txt LICENSE.txt OSHW_logo_nGen.gcode OSHW_logo.stl
