Hi,
When I go to print the filament does not come out. I have changed it a few times and able to purge the system no problem. It unloads and loads just fine.
Very new to this. Just starting up again.
Thank you
krk
Hi,
Thank you
krk
What machine? Is it reaching temp? Are the gears on the extruder turning? What filament? What slicer? What toolhead?
Is the nozzle too close to the bed for it to come out? Does it come out but stops after printing a while?
Hi.
lulzbot taz 6. Temp=yes, gears on the extruder turning=yes, What filament = PLA 3mm, What slicer = ? What toolhead = ?
Nozzle may be too close. I stop it mayber before it does.
Thank you
krk
If it pushes the bed visibly in any way when it does the measurements on the washers at the corners, your level has failed, even if it completes all four corners. Clean the nozzle completely.
That was my current plan. Thank you for your help.
