TAZ 6 - Hello, having an issue with homing and the x-axis. I know it should be at -15 starting out, but its stuck at -20 and i cannot fix it for some reason. It causes the nozzle to miss the first probe point and misses the wipe pad by a few mm. Pictures attached, thanks in advance for the assistance.
Do you have hotend offsets? or a change in the startup GCODE?
For a single extruder, it should all be zero:
Those printhead settings there just tell the slicer what safe travel limits are outside the print area so it doesn’t throw an error when it moves to the zeroing button, wipe pad, or washers. I do not believe it does anything to adjust the print offsets.
Also, check that you have selected the Single Extruder in the Toolhead menu on the printer.
If the correct toolhead is selected in the firmware, and it’s not hitting centered on the zeroing button, verify that your X limit switch isn’t getting triggered early. You’ve got some issues going on in the picture that should also be addressed before even trying to print.
If the button is triggering right, you can physically move the Y axis over. Refer to step 9 for proper mounting position.
If you can print a 135mm spacer jig, it makes things much easier.
