Looking for a diagram for inserting the pins into a new harness for the extruder motor, the thermistor, and fans for swapping out tool heads.
I have a few stepper motors, half height and the stock steppers, pin housings, a bunch of hexagons heater blocks, and a variety of nozzle sizes that ive printed up all the extruder assembly and mounting pieces for so I can change out nozzles by just removing the top hex head screw and disconnecting the wiring harness. I don’t want to remove the pins from the stock extruder because the tension tabs get ruined and they are a pain to bend back so that they will grip on reinsertion. I know the logical step would be to pull back the heat shrink to see which colored wire goes to which pin socket, but I dont want to risk damaging the wires. Does anyone have a pin out for the pin harness for connecting the thermistor, fans, heater, and extruder motor?
