On the left a small part printed on Prusa i3; ABS 0.2mm layers.
On the right, same part printed in Lulzbot TAZ4 with Slic3r ABS profiles, medium quality. PET surface.
The ABS are different colors but same brand.
I think he is looking for something from the edge-on as opposed to from above at an angle. Seeing that can differentiate between different types of banding and help narrow down the cause. Check your hobbed bolt for plastic in the teeth. Sometimes if there is one or two adjacent teeth with plastic in them, and the hobb makes one revolution every two or three layers it can look like screw-related banding when it’s really extruder-related. Are the bands are the same spacing as the screw threads?
Yes, the wobble is about the same distance as the Z screw threads. But is not simetrical in both sides. In one side of the cilinder the bands are higher than the oposite side.
Something like this:
Side A:…Side B:
