I am really hoping that someone can help me out here… I received my Taz 4 about a month ago and I have been trying to figure out this problem ever since with no real results. My Taz did arrive with shipping damage and I have had to replace the corner frame supports because they were broken before the Taz ever made it out of the box
Since then I have re-squared everything. I have also assured the X-Axis rods are parallel to the glass bed and the bed assembly now sits flat against the the desk (which is also flat/level).
However, I am still running into problems with leveling the bed on my Taz. It seems like no matter what I do I run out of travel in both directions. The worst part is that it is that it happens in opposing corners. Meaning that, in order to get close to level, the front left and rear right clip are all of the way/almost all of the way tightened against the bed. Meanwhile, the front right is completely unscrewed and the back left is close to the same. This is the only configuration that has gotten my bed anywhere close to level, and it is very far from ideal.
I went ahead and included a graphic to better explain what is happening. Any help/ideas are greatly appreciated!
Thanks,
Kevin
