I’ve recently upgrade to Cura lulzbot 4.0 and upgrade my Mini2 firmware. Everything is great until I power cycle my mini2. My mini2 would keep missing the wiper and the leveling probes. However when I upgrade firmware again, everything works as should but after power cycling I have the same problem. I moved back to Cura lulzbot 3.6 and everything is back to normal and haven’t had a problem since. Has anyone had this issue?
I would definitely suggest trying out the experimental version of Cura 4.13.9 v4 from our website.
Download and flash that firmware and see how that works for you.
Thanks. The experimental version seemed to fix this issue.
