I was looking at using cura and it seems the lulzbot version of cura is an older version. Has anyone tried using the newer version with a Taz?
– Wink
– Wink
I had a short look at it last week. The only differences I was able to find is the missing option to set a Z-offset and a blue color instead of the light green.
But I wasn’t comparing the resulting gcode, of the original is a more recent version it might have a improved path planner?
Did you get the new Cura working with your Taz?
I use pronterface for printing, so i can’t say if the direct control is working. But i see no reason why it shouldn’t work. .
oops I messed up the attachments…
So the naming/terminology is a bit messy…
The “original” or “legacy” Cura https://github.com/daid/Cura is based upon a windowing system called wxPython. It was initially created by Daid, then later supported by Ultimaker. This is an older screenshot, but it looks like this:
The LulzBot Edition of Cura https://code.alephobjects.com/diffusion/CURA/ (and synchronized to github too https://github.com/alephobjects/Cura) is derived from Daid’s. Looks like this:
Is there an alpha or beta version of the lulzbot version of Cura “2.0”?
No, but when the time comes there will be an announcement made on the forums. I’ll drop a comment in this thread about it too.
Txs
