I’m trying to print a tall cylinder, and I’ve noticed that the higher it gets, the more “off” the rings are.
Here is the bottom, which looks good:
Here is the top, which has gotten messed up:
From searching through the forum, I guessed it might be related to 2 things, either it’s somehow related to the temperature being cooler the farther away from the heated bed it got, or something related to vibrations of the printer itself. I’m not sure how to truly test if there are small vibrations, the printer is on a level surface and I printed a large, flat base to keep it from tipping.
Should I try and create some kind of enclosure to keep the temperature more consistent, or am I perhaps completely off base with what the problem likely is?
Thank you!
