Just got my Taz 6 with a dual extruder v3…
I’m having a few issues.
is this tool head play normal? lulzbot Taz 6 dual tool head play - YouTube
The hot ends keep heat creeping regardless of my retraction settings… is there a fix?
That play isn’t normal. You may need to do some “fine tuning” of the bottom of the tool head back plate.
There are a couple of fixes for the heat creep. I’m assuming you have a Dual Extruder V3 and if so, the V3.1 conversion kit should help but I prefer this one. With care, you can use the stock fan without cutting the wires. There are also higher CFM 40mm 5v fans available from Noctua (NF-A4x10 5V and NF-A4x20 5V).
If you want to really get carried away, https://www.thingiverse.com/thing:3098955 or https://forum.lulzbot.com/t/duel-v3-heat-creep-fix/6881
