Hmm, I would first recommend updating to Cura 3.6.18 as the 3.2.32 version is quite a bit outdated. You can see all of the improvements we have made sense then here: https://code.alephobjects.com/w/cura-lulzbot/ You can get the latest here: LulzBot | Cura
You will also notice on our next release notes, we made an update to the firmware to help the TAZ with the accessory tool heads. Please update the firmware, re-slice the model using the latest cura LE and give it another try. If you can print from SD card it will also eliminate any possibility of communication issues via octoprint or USB cable.
I did the upgrade per the instructions, which included the firmware update. I will try your suggestions and report back! Thank you for the quick reply!
I looks like the Cura LE profile for the printer when I initially set it up had “Marlin (Volumetric)” as the default GCode Flavor. That was the only difference I could see as I set up another printer for testing over USB with Marlin as the GCode flavor and that went well. I did the 20x20mm cube test and minus a couple of under extrusion issues, the test is what I would expect. Thanks for all the help here to get me rolling.
