Looking for a donated RAMBo board for a TAZ 5
Hey all. I’ve got a TAZ 5 that started beeping and slamming the gantry after I swapped in a new thermistor. Turns out the thermistor was never seated in the board header — it was just hanging loose. Now the board won’t talk over USB and won’t take firmware from SD, so I’m guessing it’s fried.
I’m a broke student working full-time in IT, so I can’t swing even the forty-dollar used board on eBay right now. If anyone’s already upgraded to an SKR or Archim and has an old RAMBo sitting in a parts bin, I’d be incredibly grateful for a donation. Happy to pay shipping if that’s the only ask.
Printer’s a 2015-ish TAZ 5, single extruder. Thanks for reading.
I have an skr mini e3 v3with a stuck fan 0 the part cooling fan mosfet but if you switch fan 0 and fan 2 the electronics fan mosfet it will work like normal just with the electronics cooling fan always on like the original Rambo. You will have to swap the pins in firmware and make custom firmware but it is a 32 bit board so it can do input shaping on marlin.
Thanks for the offer! An SKR Mini E3 v3 could definitely work. I’m fine swapping the fan pins and building custom Marlin, and input shaping would be a nice bonus. Were you thinking of donating it, or would you want something for it? Money’s tight right now, but I’m happy to cover shipping. I also have a spare TAZ 5 stepper motor (the one that drives the tool head) that I’d be glad to trade or donate back.
Which version Rambo are you looking for?
I don’t think the rambo boards were ever configured by lulzbot to do firmware flash from the SD card (never tried it), but the first thing to test if it’s not talking over USB is the USB ports and USB cables. Swap out with one that’s tested working with another device before going through the trouble of doing a new board.
Thanks for asking! It’s a RAMBo 1.3, the one that came stock in the TAZ 5. If you have one you’d be willing to part with, I’d really appreciate it. I’m happy to cover shipping, and I have a spare TAZ 5 extruder stepper motor, with the drive gear that feeds the filament, that I’d be glad to send or donate back.
Thanks for the tip! I’ve already swapped in a different USB cable and it still won’t connect, so I’m fairly sure it’s the board. Good to know about the SD flash, too.
@zenotek Thanks for asking! I’m looking for a stock TAZ 5 board, so a
RAMBo 1.3 or 1.3L. A 1.4 would work too if that’s what you have, since
I can handle the LCD cable and firmware tweaks.
Wrathernaut, thanks for the tip. I’ll test with a different known-good
USB cable and port first before going after a new board.
@masr1234 Just following up on the SKR Mini E3 v3. Could you let me
know yes or no whether you’re able to donate it? If not, no worries at
all, I’ll pursue another route. I’m happy to cover shipping either
way.
I do not think I can but could you check all the fuses on the board in case one of them blew.
I don’t have a 1.3 board but instead a 1.4. To use it you would need new cables for the screen to work.
@masr1234 Thanks for letting me know, and for the suggestion. I’ll
@zenotek I’d gladly take the 1.4 board if you’re willing to part with
it, and I’m happy to cover shipping. I can sort out the screen cables
myself, but do you happen to have them? If so, I’d be glad to take
those too.
It’s a fairly bespoke cable the Taz5 uses to connect the screen, not sure it’s going to be easy to convert that one to work unless you use a bunch of DuPont connectors to rewire the connection to the board.
Quick update on the symptoms: the board powers on, but the LCD keeps flipping back and forth between menu/settings screens on its own and beeps each time, like the knob is being turned or pressed. It also still won’t connect over USB, even with a different cable. Has anyone seen this on a TAZ 5 RAMBo 1.3? Could it be a bad encoder knob or LCD cable instead of the board? I’m planning to try it with the LCD unplugged and then try USB again, but I’d appreciate any pointers.
Try unplugging the screen and connecting with USB.
Definitely worth a shot. Display could just be flooding the board with inputs if it’s failed, and the machine works without the display.
