M175v2 Tool Head - Heater Cartridge Replacement
I need to change the heater cartridge on my M175v2 print head. I have successfully removed the heater cartridge from the heater block. What is the best way to remove the two connector pins from the wire connection harness so I can finish the removal and not damage the connection harness? Is there a special tool I need? Do you sell it? Thank you for your help and support.
If the pins go directly into the 20-pin molex connector on yours, it requires a special pin extraction tool - Amazon.com: JRready ST5255-05 Pin Extractor Tool Kit Terminal Removal Tool with 5PCS Replacement Tips for Molex Mini-Fit Jr. Micro-Fit 3.0 3P/4P PC Fan, AMP Micro Mate-N-Lok Series Connectors : Tools & Home Improvement. You can try and make do with something else like this: https://www.youtube.com/watch?v=T43tyxyIXxU
Thank you so much. I purchased the tool and all is good.
