Does anyone know the correct nozzle temp for t-glass, not worried about the bed, I am using painters tape. Thanx!!!
From the taulman website:
“Optimum temperature is about 212c to 224C, but will print down to 207C and up to about 235C.
NOTE: A feature of t-glase was to select a polymer that easily sticks to heated acrylic and glass print tables for the smoothest bottom surface possible. While t-glase meets this requirement, it results in a low glass transition temperature. The effects of a low TG is that parts printed in t-glase, should not be exposed to high temperature use or applications. The measured TG of t-glase is 78C.”
Hope this helps,
Kent
We have some information here: http://devel.lulzbot.com/filament/HOWTO/HOWTO-T-Glase.odt
