I am trying to get octoprint running on a model b+ raspberry pi. I am using the most recent octopi build. The rpi boots and Octoprint runs. I can connect to octoprint via the Web browser but I can’t seem to get octoprint to connect to the Taz via USB. It says connecting in octoprint but never actually connects.
I have tried the connection with and without a powered USB hub between the rpi and Taz.
Has anyone else experienced connection problems like this.
We’ve run octoprint on a lot of machines with BeagleBone Blacks. Make sure the baud is 115,200 and using port /dev/ttyACM0. IIRC, you can turn on debug, and it will log to ~/.octoprint
pi@octopi ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
pi@octopi ~ $ lsusb
Bus 001 Device 019: ID 27b1:0001
pi@octopi ~ $
So like y’all, I’ve been having trouble connecting to my TAZ4 from my raspi. I just discovered that if I install the SD card, it connects right up! Does this make sense?
I have continued to have some trouble connecting to the printer after the printer has been power cycled. Most of the time, it takes a rPi reboot to have a successful connection.
My SD card is not installed… I will put it in and see if that helps.
