I tried printing this on my Taz 4 using the AB S settings, and changing the temps to 230 and 60…
It printed, but it was really gloppy and lots of loose strings…
What settings should I change?
Does anyone have a Cura setup for this material?
What layer height are you printing?
PETG can be tough to dial in. Especially at higher res.
Check filament diameter, make sure you’re not over extruding.
You may need to increase retraction distance and speed.
Also, try dialing back the extrusion multiplier.
I would start in that order, print some calibration cubes after each adjustment.
Look at this link: http://forum.makergear.com/viewtopic.php?f=11&t=2593
