I want to see if I can purchase just the display for the TAZ 4/5 display. I am capable of replacing it but I can’t figure out exactly what part# it is or where to buy one.
Mine has had some issues (visibility) on the left hand side since it was a few months old but now that it’s 1.5 years old I can’t see the > mark that you use to select items in the menu.
I should be able to buy just the display for far less than the $69 they get for the controller, or at least I think I should be able to.
Anybody got a link to part #'s or better yet a source?
Mine has that same failure point if it’s any consolation. In likely the same exact spot. Heat from the SD card slot seems to be the main culprit near as I can tell.
Oh, just the LCD? Huh. I don’t know that part number. It’s a DOGM128 implementation of a white on blue 128 x 64 LCD. This one should work: https://www.adafruit.com/products/188 which is a Vishay LCD-128H064A
Well forget the $10 ebay one, even though the pinouts are exact it seems something is different and it did not work. I could actually remove just the LCD glass and change it (I did save it) but I won’t try that until it’s much worse. It might be just the zebra strips are getting a bad contact in an area due to heat as well.
