In order to install a motor damper on the TAZ 6 you’ll need some additional clearance between the motor and the surface the printer is on. This post contains a modified Y Motor Mount which raises up the motor: Taz 6 Vibration Damper Compatible Y motor Mount
Then you’ll just need to get the appropriate size screws.
